- 9 Sep 2008
- Glasgow
Do you guys recon windows firewall will do.?
or do you recomend a 3rd party firewall for xp.?
I use comodo because I want to filter outbound connections. If you are not arsed about that then windows firewall is fine.
they suck donkey balls and cause more problems than they claim to fix.
Software firewalls? None.
Use a router instead.
Don't waste your resources on a 3rd party Firewall.
Use windows firewall, Avast AV
For a start zone alarm sometimes locks out network connections when windows is updated.
custom pc reported about 6 months back, somthing like a 60%+ compared to the likes of symantecand avg couldn't find a virus, even if it was called VIRUS.EXE
this is what i usually install, along side windows defender.
just stick to that then![]()
Use windows firewall, Avast AV & sweep once a week with Ad-Aware & SUPERAntispyware, JD.
open your network connections on zone alarm to a spacific range or ip ...
Difficult to do when you can't remote on to said client pc because zone alarm is blocking you. Or when it's a corporate client which has these locked down. The problem isn't that the policies need changed - it's that Zone Alarm blocks things it shouldn't without changing a policy.
it always asks what to block unless the settings have been set to high... could be typical user error ?
