Is this a problem? Currently i have:
Primary Master IDE: N/A
Primary Slave IDE: WD 320GB
Secondary Master IDE: Plextor DVD-ROM
Secondary Slave IDE: NEC DVD-RW
Third Master IDE: WD Raptor 74GB? (it is connected to the SATA input on my mobo?!?)
When i went to format the Raptor everything went as planned, however when i got into Windows the Raptor was the H: and won't change in disk maintenance as it is a system disk now?
Have you personally done that ??? I find that very hard to believe especially if the drive has partitions like it should!!
