18 Apr 2011 at 13:56 #1 Dokinator Dokinator Associate Joined 14 Apr 2011 Posts 996 Location Essex United Kingdom What is your current CPU temp °C? It would be good to see what the range is between people CPU temps. Mine is 29°C
18 Apr 2011 at 13:59 #3 Marine Iguana Marine Iguana Soldato Joined 25 Sep 2008 Posts 6,767 Location Orsett, Essex 85°c 84°c 83°c 84°c
18 Apr 2011 at 13:59 #4 Marvin Marvin Soldato Joined 27 Nov 2009 Posts 3,869 Location Maidstone, Kent -4°C
18 Apr 2011 at 14:00 #5 Schizo Schizo Soldato Joined 19 Feb 2008 Posts 13,676 Location Home anyec kuhler in a haf-x with standard fan on the antec at the moment.
18 Apr 2011 at 14:00 #6 Dokinator Dokinator Associate OP Joined 14 Apr 2011 Posts 996 Location Essex United Kingdom Marvin said: -4°C Click to expand... Joke? Or are you using liquid nitrogen or something?
18 Apr 2011 at 14:01 #7 Marvin Marvin Soldato Joined 27 Nov 2009 Posts 3,869 Location Maidstone, Kent Dokinator said: Joke? Or are you using liquid nitrogen or something? Click to expand... Only two posts on. Damn... Joke. Actually hovering around 38°C right now.
18 Apr 2011 at 14:05 #8 SeraphX SeraphX Soldato Joined 7 Jun 2010 Posts 7,166 Location Sussex 30oC, amd phenom II X4 955, 4.2Ghz custom watercooling, CnQ turned off
18 Apr 2011 at 14:09 #10 jak731 jak731 Soldato Joined 17 Mar 2007 Posts 5,508 Location Plymouth Gets pretty hot according to the motherboard sensor
18 Apr 2011 at 14:10 #11 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester 25'c
18 Apr 2011 at 14:14 #12 Dokinator Dokinator Associate OP Joined 14 Apr 2011 Posts 996 Location Essex United Kingdom 30oC, amd phenom II X4 955, 4.2Ghz custom watercooling, CnQ turned off Click to expand... Same Processor as me
18 Apr 2011 at 14:15 #13 Menthis Menthis Associate Joined 24 Aug 2010 Posts 533 Location Southend-On-Sea 30°C
18 Apr 2011 at 14:27 #14 Stoner81 Stoner81 Associate Joined 8 Jul 2010 Posts 2,264 Location Derbyshire Air cooled at the moment as I am waiting for the Antec Khuler 920 to come in stock. Stoner81.
18 Apr 2011 at 14:30 #15 xiphrex xiphrex Associate Joined 21 Sep 2003 Posts 1,436 Location Leicester 40C - very warm in this room tho!
18 Apr 2011 at 14:32 #16 Ewanb75 Ewanb75 Associate Joined 15 Jan 2007 Posts 1,928 Location Dumfries, Scotland 36'c
18 Apr 2011 at 14:59 #17 sithlord sithlord Associate Joined 1 Jun 2007 Posts 840 What would be interesting also is what the cpu temperature peaks at on LinX download here http://www.xtremesystems.org/forums/showthread.php?t=201670 Mine: i7 920 Stepping C0 4 Ghz 1.41v After 5 passes = Maximum temperature 86c
18 Apr 2011 at 15:08 #18 jak731 jak731 Soldato Joined 17 Mar 2007 Posts 5,508 Location Plymouth 4GHz E8400 C1, 1.35V, 72c. Using a TRUE.
18 Apr 2011 at 15:14 #19 ryu ryu Associate Joined 25 Oct 2002 Posts 1,148 26 32 26 31 arctic cooler rev2 w/ ac diamond
18 Apr 2011 at 15:15 #20 SeraphX SeraphX Soldato Joined 7 Jun 2010 Posts 7,166 Location Sussex sithlord said: What would be interesting also is what the cpu temperature peaks at on LinX download here http://www.xtremesystems.org/forums/showthread.php?t=201670 Mine: i7 920 Stepping C0 4 Ghz 1.41v After 5 passes = Maximum temperature 86c Click to expand... Max temps on max load on my Phenom II 955 = 43oC at 4.2Ghz
