- 15 Mar 2010
- Bucks
I understand the initial startup cost would be high, at a rough guess I'd say about £10k. The time part is the problem I have, I wouldn't want to spend hours a week cleaning and sorting out the water, which is why I'd be looking to hire someone to do that, leaving me to enjoy the tank, feed the fish and do minor bits and pieces.
The point is it would be a feature "wall" in the main living area (put in at the same time as a house renovation) so the cost wouldn't feel as much of an issue in the same way a normal tank would be. It'll be a year or so before I contemplate it seriously anyway, plenty of time to look up marine tank systems and processes (I used to have a tropical tank - I understand marine is much harder).
In all seriousness if you can not be bothered/dont have the time to maintain a tank then you should not have one -especially Marine.
Part of getting fish is actually understanding the environment you are putting them in , and the needs of that environment and how to make it sustainable.
I have a 240l Tropical tank and even that required a lot of research to setup, stock and maintain. Its not enough just to know you need to do a water change for example - its learning why you have to do it thats important.
Marine is on a whole new level, you need to factor in the installation of a RO unit in your house, the sump, auto-topper, protein skimmers etc....and this is before you have even thought about lighting, the cycle and stocking.
Guppy randomly dead this morning. healthy as anything yesterday when i had a sit down with them.... Even dead he looked perfectly healthy (well besides being dead)
Must be all this heat. Water is in perfect condition :/. The guppy was from the first lot of fish though...
Guppies are ****. They have been bred and mixed so much their now basically worthless in any tank. Way too fragile.
Not sure on your tank size, but if its 100L+ take a look at Dwarf Gouramis, in particular the royal neon variety are very colourful, they are also super chilled fish.
