Anyone here know anything about plecos? Trying to identify this one!
Hypostomus cochliodon? Looks like a juvenile maybe as the fins are still speckled.
certainly wouldn't go in a community tank. Just find them pretty interesting and people tend to describe them as very hardy. a lot of work went into my old tropical setup and would rather avoid anything to crazy and worrisome for when I have to go away.Had one once but by accident not purpose. It was the boxing type not the harpoon. I thought it was a pistol shrimp at first but the inscenet 'clicking' at lights out coupled with missing snails and broken shells meant I had to strip the tank down to find the offending rock he was hiding in. No amount of fresh water, carbonated water etc would get him out. I eventually got him out by putting the rock in a bucket of very hot water.
I occasionally see peacock mantis in the LFS although it is rare. I'm sure a decent LFS could get you one if you REALLY wanted one but I wouldn't put them in a community tank.
Keep up with water changes, stop nutrient build up, keep lighting levels in order, old tubes cause lots of problems.
Thanks for the advice. I never knew old tunes could cause issues. I have no idea how old they are, could easily be 10 years old now though I'd say. I will look at getting a pair of new ones.
Some fishy shots:
I change my t5 tubes every 6-8 months, keeps the correct spectrum of light for the plantstry it and keep up the water changes weekly or every fortnight, the algae will go away but not over night.
Been a few years since having fish, but just had to get back into it.
So I bought a second hand Juwel 180 Vision. I have a couple of Aquamanta EFX200 external filters, one running with a UV steriliser and one running an external heater. I've upgraded to T5 lights as well. The old T8's needed replacing anyway, but as I was intending a planted tank, T5's were the way to go.
Substrate is aquarium plant soil (1-2" deep) with sand over the top
For plant food I'm using a TNC complete feed and their TNC liquid carbon, dosed accordingly.
How did you convert to T5?
Ah right ok! I'm going to have to manually remove as much as I can, get some new tubes and do the water changes and hope for the best.
Will a certain type of live plant hepl with the nutrients?
get a power head for good flow throughout the day.
Amano shrimps are really good cleanup for algae on plants, get 3-4 feed them they do well, get a power head for good flow throughout the day.
Plants i use these, always very good shop.
Sorry must dash i got work
https://www.aquaessentials.co.uk/
What power output power head would you recommend for a Juwel Vision 180?
I have the same tank and was thinking of adding a small power head to mine to complement my spray bar -my last attempt at Eleocharis Parvula carpet failed and a lot of that I think was down to poor circulation (I run T5 lights & a CO2 kit btw and will do EI dosing once my new setup is cycled and planted).
What I don't want to do is end up with too much circulation & ruin my lovely soil placement
I did think about removing some of the sponge from my JBL Cristalprofi e1501 to slightly increase the filter's flow rate.
Looks like a nice, healthy set up. Love the effect of the air stones at the back; I'll be doing the same soon when I restart.![]()
