- 13 Jun 2011
Any recommendation from amazon or similiar place? for a kit?
For freshwater just get the api master kit from wherever its cheapest.
I would not get any more fish yet.
How many fish have you got in there?
Is your tank a tropical or cold water (gold fish)?
For the moment you should start off with doing a 50% water change with a gravel clean so do the gravel clean first then just keep filling buckets until the tank is half empty.
Once you have a test kit we can see what the levels you can then do more water changes as needed we are talking testing each day and changing water as I doubt you have built up the full cycle.
Oh like mentioned in the post above forgot to say you need to add an additive to the tap water that removes all the bad stuff before you put it in the tank. I am sure myself or someone here will help you out once we know a little more info
I would think you might be on the nitrite bit in short
Ammonia and nitrite can kill fish easy the last part of the process nitrate only kills when the ppm parts per million gets really high. The other affects of high nitrate before it kills fish is stunted growth and deformed young fish.
Once the tank is cycled you are only getting rid of the nitrate you would normal still clean the gravel and change 25% minimum a week
Itc are about 15 mins from me but i need to go charterhouse anyway to return the rollermat will save on postage and ive never actually been there.
They should just swap it out seen as its 2 days old
Tank is cold water.
OK, I did a 50% water swap today. But as for the gravel, how is the best way to get it cleaned?
40% water every 2 weeks. The tank is this
Not if your trying to grow plants. If its just a fish tank only or one with fake plants you will be fine.
I have tried to suction some of it out, but the vaccum I bought took about 35% of the water out too
Testing kit arrived, and it's not good.
What is the best course of action? I forgot to photo the first ph test, but that was the only one which was ok.
