- 13 Jun 2011
I'm having to find a new home for a Pearl Gourami, she's got way to aggressive and nothing I've tried seem to keep her distracted
Stick a mirror to the glass on one side
Thing is it's only around feeding time and maybe for an hour after. At other times it's completely calm.
Something I might try is sectioning off part of the bottom with mesh big enough to let the Corys and shrimp in in but not the gourami. Then I can drop the bottom feeder's food in there so they don't get harassed.
The main problem is she will gobble up all the floating food and then move on to everyone elses.
Anyone got any tips for taking pics of the tank?
My iphone seems to hate it and everything just looks blue
tempted to upgrade my eheim classic 250 - its on a 125L tanks with a medium stocking and performs ok but you know, upgrade-itus. Anyhow whats the most filtration you can realistically put on a tank - guessing the Fluval FX4 would probably be too much
You can never have to much filtration imo, get the wallet out and enjoy
Filtration - no. Flow - absolutely. Bigger filters come with more flow so this isn't the best advice and its more than likely a waste of money you could use elsewhere to make fish keeping easier.
God damn lesson learnt..... So after having my first brand new "all in tank" realised that nothing comes for free and experience in fish keeping in key.
After buying 200ltr tank and using the FLuv 4 bla bla.... tank died quickly, joke! I also didn't wash the sand.... as i thought it was sand!
Anyways bought a much better external filter, spent 4 hours washing gravel sand and installing everything i needed.... 3 weeks on wow, what a difference! Loving how easy it all is now!
I know you stand buy it and its true you can't over 'filter'. But literally the only reason to buy a bigger canister filter is to get one with more flow (if its even needed) or a heater built in. If then you turn the flow down (which many don't actually allow) is the definition of a waste of money. Why not invest the money in something else that makes fish keeping easier or something to increase your enjoyment.
E.g. a python water change hose, upgrading the stock lighting so you can grow more challenging plants, some fancy wood and rocks to try aquascaping, CO2 system, 2nd nano tank etc. etc.
Hey guys, we've got an empty Fluval 180 Tank. What pump and filter should we go with, since it has ports for external canister filter does anyone have decent recommendations for the tank?
And is it possible to home a angel fish in the tank maybe with some smaller non aggressive fish?
Bigger canister filter= more biological media and More filtration 2 reasons right there.
Honestly some of your arguments just make me shake my head
As for @Siliconslave the Eheim classic is An absolutely fantastic filter and i would personally recommend it above any other available. If you
Want to upgrade for the reasons i posted then i would be sticking to Eheim and getting the
Next model up. Imo tho it isnt needed unless your struggling with levels or need More flow etc.
Pointless upgrade uness you are going to move some equipment out of the thank such as a heater or powerhead.
