Could it be the provided tank filter not having enough filtration ability to bring the levels down?My first tank took 6 weeks.
I added Fluval Cycle Water Treatment with the required amount for the first couple of days then nothing since.With tank cycling the only cure is time. Did you dose the nitrite or has that been produced as a byproduct of the ammonia processing?
Seachem Prime Concentrated ConditionerTo be honest, your water change probably did more damage than good when trying to cycle. What dechlorinator did you use?
Tank is a Marina Vue 87 with a Marina i60 internal filter : http://uk.hagen.com/Aquatic/Filtration/Internal/A306
Just need to give it time for the level of good brateria to build up and break down the Nirites. That fact you have some Nitrates shows that it is breaking down the Nirites.
https://www.seachem.com/prime.php
Before the water change the Nitrate colour test was a darker orange/red.His nitrate levels are lower than mine are when I do readings straight from the tap![]()
What are people doing to keep there tanks cool in this weather.
My tanks are up to 29C now. Ive been putting bottles of cold water n but not making a huge difference.
Got itThe filter looks fine for that tank size, as others have said you just need to give it time.
While the filter has a concentration of bacteria, all surfaces in the tank will be covered in it (once cycled!). Contrary to the internet’s view, you don’t tend to need huge filters to support life in sensibly stocked fish tanks.
New tanks take a long time to build up the bacteria as you are starting at effectively zero.
That's on his Xmas list - Marine tank with live rocks, coral and plantstank will look so much better with a natural look and keep the boy more interested long term , aqua soil root wood and easy to care plants look so much better.
