Charterhouse aquatics are they any good, looking to get back into tropical and lost touch with retailers ?
Thanks
one of the shops i use a lot, can't fault them
Thanks
Thanks for the teplyone of the shops i use a lot, can't fault them![]()
Currently housing 4 mollies, 5 guppies, 3 shrimp and 3 assassin snails.
https://i.imgur.com/OkXi5jf.jpg
Nice bit of wood you got there. irc that plant on the left is more for terrariums so it may die off in the coming weeks. (or thats just my excuse for dying on me!..)Never thought or that, thanks for pointing it outI wouldn’t have thought the one that comes with it comes in retail packaging?
Hi I have been looking for a used 200l tank with external filter and none in my area so thinking of just buying new and that’s why the questionsIt’s worth asking but I wouldn’t get your hopes up.
Hi yes that’s why I would go external, but will give it another week or so to keep looking for a used set upI have a U1 in a small tank which is basically the same thing, just smaller.
Some would say it’s too small but I’d say it’s adequate but only just. Plastics and motor are good quality but as I’m sure you’ll be aware it’s an ugly black box in the tank.
Looks good, i do like those 3d backgrounds.
Had that tank, filter and gravel at one point for a female beta tankNice bit of wood you got there. irc that plant on the left is more for terrariums so it may die off in the coming weeks. (or thats just my excuse for dying on me!..)
Can anyone give me opinions on the fluval U4 filter please ?
Thanks
Thanks
