One is already underneath with just the tip of the shell showing!Don’t be surprised if they disappear into the gravel, that’s be design and where snails like to breed. They are chasing the food.![]()
What fish you got sometimes not feeding is bettergoing away for a week, anyone used those feeders to feed them while you are away any recs ?
I used to use this one.going away for a week, anyone used those feeders to feed them while you are away any recs ?
EasyFeed Automatic Feeder
The JUWEL automatic feeder can be used in any aquarium. Using the right mounting support, it can be fitted particularly simply and quickly to any JUWEL aquarium. It can be programmed for two feeding cycles a day and allows you to feed your fish at intervals of six hours. The volume of the...www.lincsaquatics.com
Its ok providing you crunch up the food first and make the slate at the smallest. Otherwise it dumps a lot into the tank.
Nowadays I have to have a fish carer come round due to my tank being an aquascape and needing daily ferts etc..
do you not have the light on some sort of timer (device/bluetooth app)?yes i am thinking just ask someone to feed the fish once every 2 days and leave the light off ?
If your fish all look healthy, simply give them one generous feed before you go.going away for a week, anyone used those feeders to feed them while you are away any recs ?
That's my policy when we go away for 5 days now, I used to ask family/friend to pop in and almost everytime I did I came back to at least one dead fish. But all good after being "starved."
My tanks get a "famine Tuesday" every week anyway, because like many others, I'm sure I slightly overfeed adult fish. The only only exception recently has been feeding my ~13 year old Leopard Bushfish, netted him/her out of the African 6-footer a while ago and I thought I was netting out a dead fish, amazing how well they have recovered while sharing a 4-footer with a ~10 year old Rubbernose Plec for ~8 weeks now.
I had one of those, I broke it and how use a Oase one but its very similar. I do find that even on the minimum settings, too much food comes out if you are using small/micro pellets. Flake doesn't work, way too inconsistent, sometimes you get nothing, other times it seems to dump loads in. I find standard Fluval tropical bug bites tend to dispense consistently and appropriately for my 80L tank on the lowest setting.I used to use this one.
HUE is popularyes but may just leave the curtain open a tad as and when the sun passes as its in the living room
