Z77X-D3H, 3570k and 1600Mhz Memory Woes
I've ordered the same mobo so am glad I spotted this thread before taking the RAM.
Let us know how you get on with your new sticks.
i5 Ivybridge as well?
Could you grab a screenshot of the BIOS memory timings/voltage screens? Maybe manually configuring it would sort the issue...
Nope, I said it was an i5 2500k which is a sandy.
I'm just using the XMP profile with 1.65v. What BIOS are you running?
Apologies, if I had taken 2 secs to read your post and/or your sig I would've known that! :p
F16. Not tried the beta...
I have newer RAM coming tomorrow, which on paper is 100% compatible with this motherboard. If you have a flick through your Gigabyte manual I'm pretty sure it says it only supports DIMMs @ 1.5v. I don't know if that is a motherboard thing, or specific to Ivybridge IMC.
I've opened a thread asking 8 Pack to impart some of his wisdom...but in case anyone else is interested...
Just installed my brand new Crucial 1866Mhz RAM, enabled XMP Profile1 to get it to run at advertised speeds. Started a P95 Blend test, 10 seconds in, blue screen WHEA_UNCORRECTABLE_ERROR.
So this is happening with 3 lots of RAM, 2 of which were MemTest86+ tested for 12hours without issue, and 1 was brand new purchased 2 days ago.
This is so frustrating :( Pics as requested:
CPU Voltage
CPU Frequency
DRAM Voltage
Memory settings 1:
Memory settings 2:
3D Power settings:
Again, BIOS is 'optimized defaults' with the only thing touched being the DRAM Profile to Profile1.
I have same mainboard as you, i5 3570K, 16gb G.Skill Ripjaws memory, 7770 GPU, Kingston 120gb SSD, F18 firmware
Never had a lock up at all
edit: I've never even been in the BIOS to change anything, apart from AHCI setting
Cheers for that. How comes in HWMonitor it doesn't show DRAM and CPU VTT under Voltages? That's what I'd be most interested in seeing bud - maybe your version of HWMonitor is out of date?
