UPDATE: zalman 9500 temps
Hi I have an opteron 146 currently at 2.5ghz and a zalman 9500 on full. I only have a few case fans but am getting more however temps do not change with the side panel off.
Temps:
Idle: 40-42
Load: 48-50 degrees celcius
Now to me these seem quite high, and so I touched the top of the heatsink base while my computer read 40 degrees and it didn't seem hot at all. It felt the same temp as the outside of my case. Do you guys think my motherboard temp diode is giving these an incorrect reading, and if so by how much? Im waiting on an infrared thermometer so I can see what temperature my cpu is actually at, but until that comes I just want to make sure it isn't actually running this hot.
I put some arctic silver on it, and lifted up the heatsink to make sure good contact was made, and it was. I have used enough arctic silver to create a shape slightly larger than a 10p in the middle of the IHS after the heatsink has been attached. Which is the amount suggested by the arctic silver application guide (about a grain of rice size).
Any input is greatly appreciated,
Thanks
Daven
Temps:
Idle: 40-42
Thanks
Daven
though, but we'll see how much they increase when I put this opteron up a few hundred mhz.
