7850 Twin Frozr III
Caporegime
12 Jul 2007
United Kingdom
OP
10 Dec 2009
Hampshire
My version says the 26th hitman. Can you post the software info from ccc please so i can check your version?
is that the right thing?
when it crashes what does it do? random coloured screen and freezes or crash to desktop?
id set x.m.p for your memory first,then look in ccc/overdrive settings and add 10% to the power control slider
it loads the menu to the game to start it after pressing continue then it crashes to desktop
if i edit it when in the game the background goes black but the chactacter is there
OP
10 Dec 2009
Hampshire
i change it the xmp in bios to Profile 1
i saw another setting normal turbo extreme for the memory it was on turbo
change any of that?
Permabanned
14 Dec 2008
Sunderland
