7850 Twin Frozr III
Caporegime
12 Jul 2007
United Kingdom
Not really good advice, I had major problems with the 12.9 beta drivers with my 7870 and a quick google search shows other having problems with them as well.
A few 7870 users i know have reported no problems. :)
thanks do you mean cap1?
and whats the best way to uninstall it?
Yes, sorry my mistake.
Best way to un-install the old driver is via my computer - add/remove program.
arnt the caps just for xfired cards? 12.8 drivers here
I think you might be trolling me. :D
Buuuuut, they're for single cards as well. :)
Caporegime
12 Jul 2007
United Kingdom
Obviously it doesn't affect everyone but I would never recommend installing beta drivers, well not to fix this issue anyway as sleeping dogs ran perfectly fine for most 12.8 users.
I can't stop recommending working drivers just because you had an issue with them. :)
just keep your bottom to the wall n you'll be fine:p
Sounds like another episode of saving ryans privates.:D
Permabanned
14 Dec 2008
Sunderland
It's not just because I had an issue. Recommending beta's (which in fact in the release notes state nothing about sleeping dogs) is a bad idea when he's using the latest official stable drivers.
I think the cause of this issue is deeper than drivers.
Caporegime
12 Jul 2007
United Kingdom
Probably but im my experience the best way to troubleshoot is through the process of elimination and you should always start with the most common problem, drivers.
OP
10 Dec 2009
Hampshire
have you tried it yet Hitman? any better with x.m.p enabled for your memory? did you re install direct x and any runtimes that come with the game?
i enabled xmp and didn't change nothing + 10% power slider ill try direct x again but i install that earlier runtimes? the things in redist?
trying the new drivers
Caporegime
11 Jul 2009
BenefitStreetBirmingham
service pack 1 maybe?
start/compter/system properties
