The Fury(X) Fiji Owners Thread
Caporegime
12 Jul 2007
United Kingdom
Not being able to overclock? :o
Ha! Yep, limited to around 7.5% overclock without voltage control at the moment. However, if you need to overclock your gpu to get decent FPS then you picked the wrong gpu. :)
I was more talking about my CPU running warmer than my QuadFire Fury X's and having a very quiet gaming rig, overall. No high fan speeds to stop things from throttling anymore, no scorching hot memory chips etc. :)
15 Feb 2011
Ha well whilst I was joking about and I didnt feel the need to OC the Fury X that I used briefly. Its still a feature that sell's GPU's and in the case of the Fury is what's needed to compete properly with the none Ref Ti's, so lets not pretend its not a desired ability. overclocking is how AMD has been selling its CPU's for 2 years now and some of its gems of the GPU world were bargains that could be unlocked and OC'd... (although I know its coming for fury etc etc)
It is indeed a nice situation to be in and good to see the lower fan position doesnt seem to be effecting the pumps performance either. I'll be having to rely on silent fan modes for a while though. :)
29 Aug 2010
Cornwall
Coming from a guy with an overclocked CPU? Did someone pick the wrong CPU?
Or perhaps people want to benchmark? Or did they just pick the wrong GPU again?
Also 50ºC for a watercooled GPU strikes me as running warmer than I'd expect. My GTX 480 maxed at about 47ºC and I considered that to be too hot.
Caporegime
12 Jul 2007
United Kingdom
Re-asses when there is voltage control. My reference QuadFire reference 290X cards were good for about a 7.5% overclock too at stock, yet they still regularly outperformed equivalent cards at 4K, including the 980 which launched a year later. :)
Not for the first time, you've lost me. :D
Good temps. I didn't realise you could get AIO's for GPU's back then, impressive!
29 Aug 2010
Cornwall
Lost you or you just don't have an answer? :D
22 Aug 2008
Why is Unwinder being so stubborn. Just let someone send you a card already...
Of course then his narcissistic god complex would suffer by being beholden to whoever sent the card. And he obviously doesn't want that.
15 Feb 2011
My only assessment is to go 390x or none X. I was heavily CPU bound with the X anyway but thats going to stay that way for me at 1440p with most top range cards until the finfet CPU's come out which will be my next upgrade cycle.
I'm thinking Fury to last 2 years so I'm not doing a GPU/MOBO/CPU/RAM upgrade all at once :) but that means missing out on the HBM2 and die shrink goodness.
decisions decisions etc
Caporegime
12 Jul 2007
United Kingdom
MSI Afterburner might not be the only overclocking tool offering Voltage Control.
Fury X is all reference design, so all the overclocking apps should have support, if they're updated.
Caporegime
12 Jul 2007
United Kingdom
And you've never overlcocked it?
If I look around the benchmark threads that detail CPU speed you won't have overclocked it then?
Oh yes, it's overclocked for benchmarking of course.
For gaming it usually runs stock (3.5Ghz) or 4Ghz if im recording videos. I have a golden sample which requires very low voltage so enables me to run very low fan speeds and still keep temps below 60C, but higher than my Fury X.
Which AIO did you use on your 480's, because those temps were impressive?
29 Aug 2010
Cornwall
Wasn't an AIO cooler, was proper watercooling.
