go play bf4 on a 2500k then go play on a modern 6700k or x99 cpu. tell me there is no difference. if people tell you there isnt they either blind or stupid.
Yeah for streaming an i7 is going to help massively.
It depends a lot on your resolution and the games you play.
Those at 1080p (and god forbid any lower) will benefit a lot from a newer CPU. Those at 1440p and higher will benefit more from a new high end GPU.
i5 750 may well be fine but if you actually compared framerate and frametimes in any game that makes good use of your CPU it will be obliterated by any modern CPU, especially a 6700k or 5820k.
Surely it's easy enough to figure out which part of your pc is the bottleneck? Simply monitor your cpu and gpu usage while gaming, which ever one is topping out first is surely the bottleneck? If you are getting good FPS, ignore and put your wallet away. Personally for me, the CPU has never became a bottleneck in the past until I started running multi gpu's, then very quickly you could see an older CPU struggle, and the GPU's weren't using all their potential. I'm a big fan of buying yesterdays best tech, you can't beat the value/performance ratio. Often the best thing about buying previous generations especially with GPU's is you can have 2 (or more!) gpu's for less than the price of the current new top end and also be faster than it.
simpler decision for me - my Q6600/P5N-D combo needs upgrading. My main problem is what to upgrade it with
Depends on your usage patterns and whether you plan on keeping the system for as long as your previous one. For longevity and multi-threaded performance, X99 is usually a better bet. For shorter-term, single-threaded power for gaming, an i5-6600K is probably best.
I am planning to upgrade to 1080 or 1070 GTX (from 570GTX) and I am wondering about going [email protected] on air depending what chip I would get from my current [email protected] ghz... I game on 1440p@144hz capable screen with gsync.
Should I go 6700k or not bother? Desktop performance of q9550 is fantastic but wonder about gaming with 1070-1080 at 1440p with high HZ.
Thanks lads
around 60%I'm still waiting, I need to see how much faster a 6700k is against my old I7 970 @ 4.5, the min frame rate must be faster on the new 6700k?
