Another update, hopefully they should start to flow faster now that everything excluding the reservoir has arrived
So first port of call is my first tubing cuts, these are two templates that have been cut out of acylic so I can cut the glass tube to the correct lengths. I'm very pleased with the overall look of the tubing and mid plate together.
Now for the best news, the GPU arrived (Thank you to rIcK). Obviously I had to test the GPU out by playing some BF4 on the new monitor. I was very impressed (Ultrawide definitely beats 4K hands down
And here is where things went pear shaped. I removed the stock cooler and attempted to install the waterblock. Issue one was the thermal pads not adhering to the waterblock and falling off meaning/moving everywhere so I had to order more. Second issue was during the test fit the thermal pads appeared to not make contact with the VRMs and RAM chips
Hopefully this should be solved when the new pads arrived tomorrow
