Well I have just fitted the H1200.
Very happy with it and took my time to fit due to first time using AIO and the instructions having a number of issues, a few outlined below
there is a number of typos or the manual is written by someone who doesn't speak English very well and pictures are not correct either.
I noticed on page 7 it states for INTEL fitting but then shows a AMD back plate and then on page 6 it states AMD fitting but then shows the Intel back plate. I had to double check this as shows different mounting positions and wholes to use for the back plate
Page 5 states the following
Please send one water-cooled copper radiator protective film tear, and the accessories N uniform thermal conductive silicone coating on copper heat sink or the surface of the CPU
Page 8 states this
Use accessories I will fan is fixed 0n the water cooled now, here fan blowing direction toward the water cooled row. After installed, the water cooled row using accessories J and H fixed to the chassis vent. According to their Owen requirements, can choose water and fan another installation location, but show follow the fan to blowing outside the box.
I heard the manual was not very good but thought I would leave my feedback on it so ACE MODDER was aware
What fans would people suggest? the Antec fans or the SP 120s? also does it matter if the tubing is at the top of the rad or bottom?
