I'll be having a giveaway when I reach 100 YouTube subs but what do I give away? Vote in this straw poll to decide . http://www.strawpoll.me/11495143
NEW VIDEO....
I'm going to 3D print a Babylon-5 PPG
J.
Another good video
Thought id join up here, got my Prusa i3 MK2 delivered the other day. Have had the M3D Micro for about a year, but found it too slow. Got to say the i3 is a big step up in print quality. And just so easy to use.
A print i made today, its to hold a GPS antenna and RX receivers on my quad-copter. i seam to be going though a lot of them.
I know what people mean, but I've bought two um2s for work and they been very reliable, never need recalibration, and we put about 100 hours print time a week on them. I'll see if I can get a um3 ordered, it would be nice to see if they've done dual extrusion reliably. My own um2 is still working well I've not recalibrated the print bed in 6 months and it stills just prints well, although it's not perfect, my next upgrade will be a bond tech feeder or maybe a flex3drive, but other than that, I'd like to do a dual extrusion setup if it was fire and forget, I don't have enough spare time to keep faffing around..
Hi,
Just got and done my Bondtech upgrade on my Ultimaker 2 Extended.
I have also just got the 3dsolex V3 block and a few Jets.
So far its allowing me much quicker printing tho some times you just cant use the speed but its a much better feeder than the standard one.
Also upgrade the tube
PTFE tube 3.18/6.4 mm diameter
I had the pleasure to see Martin (Bontech) and Carl (3DSolex) at the show in Birmingham NEC.
Both good people.
Martin was also able to help me out with the custom firmware for the printer. you can get this direct but he was happy to help me get the latest version and have it set for the new steps needed for the feeder.
Can't fault the upgrade or the people that have created them both worth it for sure.
Richard
Aliexpress has lots of discounts TODAY ONLY.
Clone E3D Titan 15% off - http://www.aliexpress.com/item/-/32737959249.html
Pancake stepper motor for the above 15% off - http://www.aliexpress.com/item/-/32747709967.html
Polished heatbreak for clone E3D V6 50% off - http://www.aliexpress.com/item/-/32465816219.html
Five TMC2100 stepper drivers 15% off - https://www.aliexpress.com/item/-/32677100938.html
These are things that are difficult to find on Ebay/Amazon.
Worst case use them as bowden
