Did you get bubonic plague?
Close
more or less
This high quality piece of tin that's so flimsy one of the nacelle struts has already snapped off
. I actually don't mind the look as its kind of different being all metal, but the flimsiness is amazing. It comes basically flat packed the saucer is in 2 half's and the nacelles aren't connected, its 7 small bolts and nuts to put it together.
The front "deflector" (its actually basically a dome with some small indents on it to make it look vaguely like one) comes off and they had a small battery box inside for 2 aaa batteries. The battery box has leds strapped to it to shine some light out of some holes in the hull. And the saucer has a random led strip dangling inside it to try and make it illuminate. But the wiring is wonky and it only works if you hold the box a certain way.
I suppose I'm somewhat surprised a facebook ad actually yielded something that looks very very vaguely like their description and video. Just waiting on their response to my email asking "wtf is this and why is it already broken", which I'm sure will have an expedient response.
