** NEW PRODUCTS ARRIVED AT OcUK!! **
15 Dec 2010
UK
My order status has changed to 'Order Allocated' - I've no idea what this means in terms of when I get it, but I'm viewing any change as positive :)
Mine is the same. I taking that to mean stock is coming and they've reserved a unit to fulfill the order.
27 Jan 2020
West Sussex
There was some chatter in the water cooling forum on this, Rev 2.0 uses a different pump (moving to Asetek) rather than with Rev 1 using Lian Li's own pump.
It's meant to address all of the issues that have been happening with the rev 1 versions and the grinding pump noises.
17 Mar 2009
Nottingham
Do you have the link i cant find it?
