Lian Li 011 EVO XL HALF LIFE BUILD
11 Mar 2016
Right!
its that magical time again to start a new build - This time around i'm going for the Lian Li 011 EVO XL with a half life theme (orange/black scheme)
So far Parts will be
LG Electronics UltraGear Gaming Monitor 32GQ950-B
Ryzen 7950X
Rog Hero AM5 Motherboard
T700 4TB NVMe
Corsair Xc7 RGB LCD CPU Block
HX1500i PSU
Corsair QX140 RGB 140mm Fans
Custom loop using Hydro X Series XT Hardline 14mm Tubing
Parts im still thinking about is
EK Water Blocks EK-Quantum Surface P420M Triple Fan Radiator Black, this give around 44mm of depth coupled with the fans 25mm depth giving a total 69mm im not sure if that thickness is too skinny for the base of the chasis as its quite large. Shown in red in the photo
I like the look of lots of pipes this build is inspiring my design. https://www.youtube.com/watch?v=dZTDTu8s9n0
Items will trickle through as i purchase and select
OP
11 Mar 2016
Small update
ordered the below so hopefully they will arrive soon.
I went for the P420M based on its 44mm height profile, i thought the X version at 58mm might be too deep, we'll see. If i dont like it i'll swap over and get 2 x.
EK Water Blocks EK-Mana G2 PC-O11D EVO DDC D-RGB Distro Plate
OP
11 Mar 2016
Some new toys arrived today....
for the rad the EK Water Blocks EK-Quantum Surface P420M Triple Fan Radiator is 44mm and too small in height for the bottom so going to use this at the top then order the EK Water Blocks EK-Quantum Surface X420M Triple Fan Radiator @ 58mm for the bottom :)
OP
11 Mar 2016
ok so i think im going to swap out the DDc 4.2 pump that comes with the plate to a D5 this way i can rely on the silent and water cooled pump.
more parts on order :D
23 Mar 2005
looks like its going to be a beacon of RGB. Its impressive seeing how much bigger it is from first picture.
The link though looks like they are never getting those bubbles out of the water and how the hell do their drain it
OP
11 Mar 2016
As mario would say.... HERE WE GOOOOOOooooooooooo
Install some components, intresting the PSU sits directly behind the CPU
I ordered the satin version of the 14mm tubing much prefere it over the clear.
OP
11 Mar 2016
Can you expand on the bubble comment?
I'm not a fan of RGB so will turn most off, however its a Half Life themed PC so orange and black
23 Mar 2005
the youtube link felt like it spend 10 minutes just showing how much air was in all components and due to the placement couldn't fill it up enough.
OP
11 Mar 2016
So on the EK Rads they come in this light grey end caps, which didnt suit the black/orange combo i was looking for so i decided to spray them matt black with some HOLST SIMP17 Spray Paint, 500ml Black from Amazon.
The finish came out really nice and its adhered to the metal lovley.
I had to cut the mounting fram to make the EK G2 Manga plat fit properly, the pump got in the way
Case coming together
OP
11 Mar 2016
Looks good!
thanks
I have been looking around at the RTX 4080 and 4090, im currently rocking a 3080 FE
After much thought and going through all the benchmarks and reviews, it just doesnt seem worth it to get a 4090 at the moment, specially if the 4080 Super or refresh is around the corner.
So for now i'll waterblock my current 3080 and put it into my new system, keeping an eye on the GPU market to see what comes out in early 2024
On route is a Corsair Hydro X Series XG7 RGB 30-SERIES FOUNDERS EDITION GPU Water Block (3080) - Fits NVIDIA® GeForce RTX™ (3080)
22 May 2010
Minibotpc
thanks
Yup the 4080 super would be a good upgrade but honestly depends on the price it releases at and whether they drop the price massively on the 4080. If they do, i could see more people buying the 4080 rather than the super especially if it comes in at under sub 1k for the 4080, even better if its sub 900 and plonk the 4080 super at 1200. Ofc that means there's gonna be a lot of annoyed 4080 owners!
Interesting choice of waterblock for the FE card, i would have personally gone for the EKWB FE block as it looks amazing and i think can be had on the used market too now for relatively cheap. The Heatkiller block would be the other option but im biased on that lol.
OP
11 Mar 2016
I didnt want to invest a bunch into a EK block and then throw it in the bin in a few months, the Corsair 3080 block most likely will be a temporary measure untill new 4xxx series cards hit the market.
It will be normal mounting for the GPU block, im not too into the RGB EVERYWHERE :o
22 May 2010
Minibotpc
I get more excited about a zero rgb build now, some blacked out stealthy looking build looks so classy imo.
