How old is too old?
18 Oct 2002
West Lancashire
My AX860 is over a decade old now and has started coil whining when the PC is asleep. It's not a problem since when the machine is on I can't hear it over the fans and when it's sleeping no one is in the room but thinking it might be the beginning of the end.
Had a look at some replacements and all the Corsair PSUs with decent specs are the SHIFT models which would require a new case too.
If it goes bang tomorrow should I get a Seasonic?
2 Dec 2022
The standard Corsair RMx (non shift) has decent specs too.
8 Aug 2012
this also makes me wonder if i should.. i got a 750w evga.. cant remeber the excat model but it must be close to 10 years old.. but i havent put it through too much strain..
11 Oct 2011
London
upon checking my purchase date with ocuk appears my superflower 1000w is about 9 years old - although it's been rock-solid I'm now questioning if its time...
18 Nov 2007
Deepest Darkest Essex!!
Depends on the hardware its powering. If its high end recent hardware then a possibility. otherwise - 'if it aint broke don't fix it'.
I've got a 8 year old EVGA 550G2 in the rig I'm typing this post on. Said rig draws 40 watts from the wall so its hardly taxed. It's still got another 2 years warranty but I'll still keep it. If it goes bang I'll have a problem deciding what to replace it with, said PSU was the first to get a perfect 10 score on the now defunct Jonnyguru PSU review site.
12 Feb 2004
Manchester
SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black purchased from OcUK Jan 2014. Still working fine in my server 24/7
Question: Does efficiency wear out on PSU? ie would it be running at 80 Plus Gold levels at the moment?
Man of Honour
22 Jun 2006
One of the big hardware sites did a test on this (capacity and efficiency with old PSUs), but I can't remember who. Anyway, there was pretty much zero difference (at least, not for the PSUs they tested).
lcg
lcg
7 Apr 2009
London
This thread makes me nervous about the Corsair HX520 I have from 2008. I have had generic PSUs blow on me in the past and this replaced one of them.
Hopefully, I haven't jinxed it!
I had a Corsair HX520 from 2007 until it went bang in 2011. Thankfully it didn't take out anything else. The RMA replacement HX650 is still going strong.
27 Nov 2005
Guernsey
I still have my old 2007 Enermax 720watt PSU running my system
( I feel it amazing that a 17 year old PSU already had the two 8 pin connectors needed to power my 2080ti)
I bought a new 1200watt Asus Thor PSU end of last year but am waiting till i upgrade my system before fitting it.
