NVIDIA 4000 Series
6 Feb 2019
Bencharked a different scene level?
Possible, however the the 1% lows can be very different and if that was related to the scene used it would mean this game has performance problems because the difference in 1% lows can vary by dozens of fps that should have been picked up by Digital Foundry in their review.
30 Jan 2017
Lincs
looking at those lows anyone who bought this gen 8gb gpu should about now banging their heads against a wall:cry::cry:
I don’t think it’s that bad. I paid £320 brand new, which is comparable to a 3060ti, which itself is 8gb.
There’s still room for an 8gb card and even though my initial question was regarding a potential mitigation, I don’t think it’s a product killer.
Anyway, my lad is only 12, he won’t be super bothered if he has to reduce textures.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
So you got it cheap, yet to me it still seems expensive for what you're getting.
30 Jan 2017
Lincs
The market isn’t great, I’ll agree there! Not sure what the alternative would be. I could have gotten a 6750xt for the same money. A much better rasterisation card but again, I favoured DLSS3 and the low power for his particular use.
Hopefully his requirements for gaming at 1080p will be fully met. Like I said, he’s only 12. :)
17 Mar 2009
Nottingham
Who says 8 pins can't also melt and melt on the PSU side as well
Your post is missing a load of context. The PSU was replaced via RMA and the original pcie connecter was left in the PC. There was a pin layout change for the replacement PSU which was missed so when used with the original cables it caused it to melt/overheat. EVGA ****** up by sending the wrong version of PSU on the RMA replacement
7 Dec 2010
Leeds
Exactly.. he has a habit of doing that and never adding a source.
Source for the issue :-
Also the picture posted came from this post on reddit
This person states it was connected to a 3080ti and daisy chained from one cable from the psu, so clearly user error and overloaded the connector :rolleyes:
VIPizzza
Op · 16 hr. ago
Yeah was daisy chained to a 3080ti
Would use two but was a space saving move, my case is tiny
Man of Honour
13 Oct 2006
Haven't bothered looking at the article, but when I've done RMAs on PSUs in the past it has usually said something like return or dispose of all cables, probably to try and avoid situations like that.
EDIT: Can't remember if I've done a unit only swap out though - mostly it has been DOA PSUs.
27 Nov 2005
Guernsey
I opened the box this evening and found this inside of it :mad::mad::mad::mad::mad:
I now have the worrying time of trying to sort this crap out
Am really getting nowhere at all with getting a refund for this :mad:
Am really starting to think my chances are close to zero
27 Nov 2005
Guernsey
Still no luck, that is terrible
After phoning there customer service and telling them what had happened,
That customer service person wanted the item returned to them and e-mailed me the return labels to use
So i posted it back by Royal Mail SD and now there telling me the item i returned had the RTX4090 missing from the Box
4 Feb 2011
Classic, could see this coming, trying to shift all blame onto you no doubt.
