Caporegime
- 18 Oct 2002
Yup, head and shoulders above most of the others tbf!!No doubt about it Sapphire are my go to brand with GPU's, the EVGA of AMD. For sure...
This work of engineering art was the RDNA 4 high end they designed, RNDA 3 was an iterative MCM design leading to this.
They have shelved the IP and scrapped the GPU.
So in response to you for AMD to put something like this on the market people actually have to be willing to buy it and pay for it, AMD know people aren't. so it will not exist.
AMD aren't just a protest against Nvidia...
Bottom line, AMD were incapable of making a competitive product.This work of engineering art was the RDNA 4 high end they designed, RNDA 3 was an iterative MCM design leading to this.
I know. Was just pointing out that this "but people don't wanna buy AMD, just want nVIDIA products cheaper" actually means AMD is not competitive. You can't sell something, then you're not competitive, your products are not good enough -at least in the eyes of the buyers.There's no proof this was even a real planned product ffs, just rumours by a known ******** merchant.
That was first 'leaked' by MLID, so most likely bs. The render is by some other supposed leaker.
Based on patent IP block diagrams AMD submitted.
How far along it got is up for debate, looks incredibly complicated so would be pricey to say the least.
It would be pricy yes, it would not be a budget GPU, but also probably awesome, its a 14 tile GPU, 9 of those tiles are GPU logic.
Remember how when the highest core count CPU in any segment Intel could provide was 18 cores and AMD were up to 64?
That was only possible because of the work AMD put into MCM.
They said a few years back they had some crossover with gpu and cpu people, chiplets coming to the gpu side etc.
People dont buy the AMD card because of lack of feature set parity to Nvidia and making a £3000 card will just exacerbate this problem. The Nvidia cards are better at RT, have superior upscaling which is more customisable and upgradable, runs cooler and is more efficient. Add Frame Gen, RTX HDR, DLDSR (really nice feature for games with terrible TAA), AI based freestyle filters on top of that and objectively there is just no reason to buy the AMD card unless you just want to support the under dog. Simply being 10% faster than Nvidia and having 4GB more VRAM doesn't compensate for the loss of these features.Yeah, they do exist, i have one of those GPU's, but i think RDNA 3 is a stage 1 incremental MCM GPU, like Zen 1.
I wish, i really wish AMD would just make this thing, and charge £3000 for it if they have to, no one will buy it even if it crushed the 5090, i think they are right about that, but what a statement...
I don't know why people keep saying no one will buy AMD even if they are faster. Just look at Ryzen 3D chips which have Intel on the ropes.
AMD needs to create compelling features for their cards, not just look at what Nvidia does and come up with an inferior version of that months later. Sadly this will never happen because AMD will divert the majority of its resources towards the CPU business and the consoles. The Radeon team will get scraps as usual.
Unless AMD decides to invest in Radeon and take it seriously like they did with Ryzen, people will continue buying Nvidia.
Mid range is also not a done deal for AMD. Blackwell midrange will be formidable considering RDNA 4 is weaker than a 7900XTX which in itself barely beats a 4080.
I know. Was just pointing out that this "but people don't wanna buy AMD, just want nVIDIA products cheaper" actually means AMD is not competitive. You can't sell something, then you're not competitive, your products are not goon enough -at least in the eyes of the buyers.
Not everyone is a die hard nVIDIA fan that will only buy that no matter what. Ryzen proved that with Intel. Problem is, instead of another Ryzen moment this gen when they should have had an easy go, AMD chose greed.
I consider Nvidia's lack of VRam a critical problem, it is a critical problem, if a card cannot run my games properly its flawed. I don't buy things that are 'inherently' broken.
AMD were losing market to Nvidia while making better and cheaper GPU's, they have a history that is more than 4 years old.
Also, i don't consider those features added value, especially on a mid range card, if i have to pay extra for them then i don't want them.
One more thing.
AFMF is now actually pretty damned good. and its game agnostic, that trumps DLSS for me.
RT, the 4070 is only faster when you crank it up so high its unplayable on both cards.
@Nexus18 What is funny is that you made it into some sort of issue that previously voiced concerns regarding Nvidia's driver package are no longer an issue to many because Nvidia finally did what people wanted. I thought the point of voicing a concern is to have them improved upon to the benefit of the many in this case. So no it's not funny that it is no longer a topic of discussion it's only logical cause the problem doesn't exist for many anymore and that is a good thing. Now all Nvidia has last is to figure out how to do a UI upgrade without it costing performance. I'm sure they will get there.
