2024 OLED bonanza take your pick from dozens of new monitors
4 Feb 2011
Isnt this like $800 i the US??. Make you wonder how much it would cost importing it?
Ends up slightly cheaper even after delivery cost and import taxes, depending where you look. Couple of sites that show the shipping and import costs alltogether. But not worth the hassle if you have to return it..
21 Jun 2006
UK
Can’t make my mind up between the FO32U2P & PG32UCDM.
There’s not a lot between them.
F032 has DP 2.1, speakers, less gamer looking, cheaper.
Asus has 90w usb c for my work laptop, passive cooling, DV, G-Sync.
I’d pick the Aorus but I really need the 90w USB-C charging and ideally G-Sync
4 Feb 2011
You'll still be fine using gsync on a freesync monitor unless I'm missing something? I just set vsync and gsync on in nvidia control panel so for 240hz = 222hz and enable reflex also set it in game to 222 if the game doesn't support reflex, has worked for me everytime on a freesync monitor.
And never enable vsync in game.
144hz = 138hz
120hz = 114hz with same method
11 Dec 2016
Oxford
Somewhy this announcement went past me
240Hz with BFI, blurbusters certified, and looks like BFI even works with variable refresh rate
It should feel smoother than 360Hz OLED
Supposedly released last week, but not a single review around
4 Feb 2011
How's that gone under the radar, huge deal for some people.
23 Feb 2009
I don't think it allows bfi with vrr. The part on the article that shows vrr is a menu option. You can choose vrr or bfi. Also it says that the bfi is limited to 120hz, which is already available on other oled screens. The advantage with the bfi on this screen is that you can change the black frame timing and can also set a minimum between 48 and 120.
Caporegime
18 Oct 2002
3 Feb 2008
I was looking forward this year for something at 38" in oled factor but at least same resolution as my AW3821dw 3840x1600. Is there anything like this?
This is what I'm waiting for, the 39" LG. 38" just feels like the perfect size for a desktop monitor for me. It's great in gaming, it's perfect for my work (colour accuracy aside). Some more resolution + OLED would be the icing on the cake.
3 Feb 2008
39in 5120x2160 panel coming but it's a ways off it seems. Prob have a massive curve to it though :D
Apparently the curve on this 38" is 2300R which feels pretty good to me, but I'm sure I'd get used to a little in either direction. Just as long as it's not trying to curve around the back of my head!
