That winds up, seeing sockets caked in paint from previous owner's laziness. It takes minutes to loosen them and mask them up!
I know, house is full of delights like this - found a ruler just buried under the laminate. Absolutely zero ****s given.
If we're upping the anti we could always go with & 1.5 tonne mini digger but that has disaster written all over itIf only we knew a guy with a mini shovel...............
You should put your foot downI know, house is full of delights like this - found a ruler just buried under the laminate. Absolutely zero ****s given.
No heating this morning
Hot water ok but while room stat was calling for heat the boiler wasn't firing up.
Suspected the 3 way valve might be stuck and this seemed confirmed by forcing it open which restored the heat to the rads.
New Motorised valve ordered from Screwfix and duly fitted. Seems ok now and saved a bit of dough by not having to get a plumber out.
Chuffed.
Didn't remove the valve. Only swapped out the motorised actuator that attaches to it.Just for my own curiosity - Do you need to drain anything before removing the valve? For future reference.
That would be fun to watch though .If we're upping the anti we could always go with & 1.5 tonne mini digger but that has disaster written all over it
Nice to see someone take pride in the finishing touches. Can make all the difference to a room.
Did you RTFM on the frog tape? It looks like you did.
I think a lot of folk just see it as expensive masking but you have to actually wet it to activate the paint block.
