Fallout 4 CPU benchmark thread(need some Zen3 and Zen4 results!)
31 Dec 2010
Sussex
Thanks for update
Small comment, 7950x3d runs were done @ 6600MT/s, not 6400MT/s ;)
My Zen3 run were also done with a 5950x (3800MT/s 1900FCLK CL13-14-12-28), not a 5850.
Okay, I'll sort those out later.
The DDR5 was of course a copy & paste error, or Excel being "helpful". For the non-existent 5850 I didn't have any help!
31 Dec 2010
Sussex
Expanded some of the columns to show the full test (it was not possible the read that the top rank had SMT off for instance):
Will have to start culling some results as the table image is just too large now.
The ideal thing would be an embedded sorted list but do not think vbulletin's table can do those and the tables it can do would lose all the colour.
28 Sep 2018
My 13600k/ddr4. 127 and 164fps
Setup/tune:
31 Dec 2010
Sussex
Two new 7800X3D results over on the AT thread:
Quite a spread between them. One is a 4080 while the other is a 7900 XTX - might be the Radeon DX11 overhead at play?
Caporegime
12 Jul 2007
United Kingdom
Doubt it, that's a thing of the past. AMD driver has less overhead than Nvidia. More logical explanation is the game has always been very favourable to green. Also, it's so old that no optimisation would have gone into it from a software perspective in a very long time.
OP
9 Nov 2009
Planet Earth
@KompuKare Didn't Nvidia try to do implement some form of multi-threading for their DX11 drivers?
Edit!!
But the Radeon 7000 series result with the Ryzen 7 7800X3D,is a huge improvement over the Ryzen 7 5800X3D with a RX5700XT. The improvement seems more than with an Nvidia RTX3000 series dGPU going from a Ryzen 7 5800X3D to a Ryzen 7 7800X3D.
31 Dec 2010
Sussex
Some results from my junkbox
I5 11500
RX 570
16Gb (8x2) 3600Mhz Cl16 (Tuned, Single Rank)
Thanks,
that gets you at #50 in the chart which is about 44% of the max scores. Not that bad for a cheaper CPU, a bit ahead of the 10400 and just behind even a 5700X.
9 Mar 2023
California, USA
Yet another 7800X3D entry.
Corvega Draw Calls: 11698 FPS: 126.2
Diamond City Draw Calls: 7998 FPS: 150.0
CPU: 7800X3D PBO OC -20
RAM: 32GB (2x16GB) DDR5 6000 XMP 30-40-40-96
GPU: RTX 3080ti OS: Windows 10
(I updated to 7800X3D just so I can play Fallout 4 VR without stutters. Thanks to everyone who posted results that gave me the confidence to choose the 7800X3d over intel.)
OP
9 Nov 2009
Planet Earth
You almost doubled your Fallout 4 performance!
31 Dec 2010
Sussex
So you've jumped from #54 to #9 and yours is the best 7800X3D we have seen so far.
Your near doubling of FO4 score is pretty consistent between S1 and S2:
Not the cheapest upgrade, but for playing FO4 (and this mostly scales to Skyrim too), this is a great result.
31 Dec 2010
Sussex
New post over on AT:
User yuke improved their rankings from #25 to #2. Mostly be swapping from a 7900 XTX to an RTX 2080:
DX12 is one thing, but for DX11 it seems that for FO4 the Radeon drivers have an overhead problem.
OP
9 Nov 2009
Planet Earth
A bit of a concern for me as I still play the game. I hope the Anniversary Edition or whatever it is called is better optimised!
23 Jan 2023
USA
Man. It doesn't look like I bought myself much.
11700 -- 60
8000 -- 73
RX 6800 (Came from 1070....0 (zero) fps diff)
Ryzen 5 7600 (Came from 4770k.....20fps diff)?
XPG LANCER RGB DDR5 Desktop Memory: 32GB (2x16GB) 6000 MHz CL40-40-40​
My previous results.
11700 -- 40fps.
8000 -- 47fps.
DDR3/RX 6800/4770k.
The result seems kinda low.....
6 Oct 2007
North West
You checked other benchmarks like cinebench? aida64
ram latency test, to make sure your rig is performing correctly.
11700 -- 60
8000 -- 73
11700 -- 40fps.
8000 -- 47fps.
DDR3/RX 6800/4770k.
