**LIAN LI GALAHAD ALL IN ONE COOLER AND SL/AL UNI FANS AVAILABLE FOR ORDER**
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
We had a small delivery of Uni fans land. All orders that are on the pre-order list before this time are included in the delivery.
You should be getting delivery emails today / tomorrow.
We do have spare stock available on some lines.
6 Oct 2004
Southampton, UK
Just ordered the 240 Galahad in Silver ... are they due today ? Also ordered the ARGB cables as im not sure if I need them to link them up to my 9 X UniFans. Anyone else running Galahad with the uni fans ?
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
Hi,
In regards to the coolers the shipment has had a delay due to high winds. I'm waiting to find out how much of a delay. Hopefully just a few days.
Caporegime
17 Jul 2010
If you want to use the SL120 stock Galahad AIO fans you need the cable kit. If you’re ditching them for the Uni fans then the fans have the right connectors, assuming you have a Uni controller.
6 Oct 2004
Southampton, UK
Well its the pumps RGB I want to control using the UNI Controller ... at the moment I will need to link it up to the motherboards ARGB port and control using the Asus Aura ... not ideal , but it will work for now while I wait for the cables to come. Im guessing I need a rgb splitter on one of the channels on the Uni controller.
I wont be using the AIOs ST120 fans.
Caporegime
17 Jul 2010
In which case the pump has the right connectors to plug straight into the Uni controller, no cable kit required.
9 Mar 2003
Not many cases even have slots for 3x3, certainly not the o-11 Mini!
It will be 1 back, 2 side and 3 top and bottom so a splitter would be needed.
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
**NEW UNI AL120 Fans released**
The new fans have a new controller with more features and even more fan support. They also have an improved air flow performance over the SL120.
- Excellent 120mm PWM fans from Lian Li.
- The UNI AL120 fans have integrated addressable RGB LEDs and outstanding performance.
- New RGB look from both sides of the fan
- Daisy Chain design with plug in system
- Updated L Connect with control of up to 64 fans
- 360 degree view
- 32 digitally addressable RGB LEDs per fan
- Software control for speed and illumination options
- Max. 1900 rpm speed at 31 dB (A)
- 64.5 CFM max. Airflow
- 2.62 mm max. H2O air pressure
- Vibration reduction material
The Controller on the SL Fans does not work with the AL120 Fan.
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
New Galahad Coolers have launched with the UNI fans now included as standard.
Lian-Li GALAHAD AIO SL 240mm High Performance RGB CPU Water Cooler - Black @ £139.99 inc VAT https://www.overclockers.co.uk/Lian...nce-RGB-CPU-Water-Cooler-Black-HS-00A-LL.html
All in one cooler from LIAN-LI, 240mm Radiator Design, Dual 120mm SL ARGB PWM Fans, ARGB Lighting on Waterblock, Intel and AMD Compatible, 5 Year Warranty
Only £139.99 inc VAT.
ORDER NOW
Lian-Li GALAHAD AIO SL 240mm High Performance RGB CPU Water Cooler - White @ £139.99 inc VAT https://www.overclockers.co.uk/Lian...nce-RGB-CPU-Water-Cooler-White-HS-00B-LL.html
ORDER NOW
Lian-Li GALAHAD AIO SL 360mm High Performance RGB CPU Water Cooler - Black @ £169.99 inc VAT https://www.overclockers.co.uk/Lian...nce-RGB-CPU-Water-Cooler-Black-HS-00C-LL.html
All in one cooler from LIAN-LI, 360mm Radiator Design, Triple 120mm SL ARGB PWM Fans, ARGB Lighting on Waterblock, Intel and AMD Compatible, 5 Year Warranty
Only £169.99 inc VAT.
ORDER NOW
Lian-Li GALAHAD AIO SL 360mm High Performance RGB CPU Water Cooler - White @ £169.99 inc VAT https://www.overclockers.co.uk/Lian...nce-RGB-CPU-Water-Cooler-White-HS-00D-LL.html
ORDER NOW
