pressure aside, with a cone the air reaching the maf sensor will be turbulent and irratic, resulting in poor maf readings, thus poor fueling
why would it be? Air going through a standard airbox will have even worse air due to the fact its taking so many bends, and in most cases goes through resonator boxes to cut out noise.
@ matt i ment 30c not 40, mistype.
And i dont know why fords bodged the design really, maybe its because of insurance group and if the car had come with 160bhp less kids would be able to afford it? or maybe it was to reduce noise? Standard ford airboxes are fine, straight in, straight out into the TB, not on the ST.... maybe you should ask ford why?
to be fair im not 100% what u guys mean by a venturi in the airbox... surely the venturi is in the inlet area way after the airbox.
I mean the venturi effect happens at the valve also, air getting sucked in, pressure increases through the port but pressure into the cylinder itself is lower than what it was before the port. This is, the venturi effect at work... The restriction of the port/valve area.
pressure increases through the restriction, but not on the other side of this restriction.
Restrictions are bad, if they wasnt why do people bother making ports bigger or getting bigger throttle bodies?
so have a mr funny guy pic aimed at u
