AsusCoolUk said:YipYipboo, why havent you put the fan in the bottom by the hard drives and the psu?
VaderDSL said:Got my P182 SE today, and got everything installed.
First impressions were hmmm ... not amazing, the top panel was not fitted corectly, one of the tabs at the front was not in the small slot, I had to force it in with a screwdriver.
But once I got started, have to say this case is lovely!!!
I've never been able to route so many cables behind the tray before!
wuyanxu said:@yipyipboo. i don't think you can have a fan in front of HDD, at least not without moding
Can someone tell me, does the hard drive cage in the P180/182 have the same silicon grommets as in the Sonata III?
I've just got a Sonata and am not happy at all with the noise and heat coming out of it, but the drive trays and grommets are great!
 How many fans does the P182 come with?
Hey have you guys had to use any extensions on your hardware to get it all wired around the back of the motherboard tray? (espcialy with the corsair psu's).
If so which ones because ill be getting this case soon.
I read that the Corsair 520W / P182SE / Abit IP35 needed an extended 4 pin adapter, however when I got it all built there was no need for any additional extensions on any of the cables![]()
I actually bought an extension cable in advance (for my Antec 850 quattro), didn't need it though, but then I wasn't able to route as much under the mobo as some of the chaps here. still get great temps though so not complaining.
Had to remove the lower cage fan to fit the psu, but that made no difference that I could measure - tho' I did add a stalk-fan for peace-of-mind.
