- http://rapidshare.com/files/28344419/2007_PLUS_Season_Update__PLUS_.rar
I'd be up for a game. Just need to get the 2007 mod. Only link I can find is the one on gp4db and thats down. If anyone has it could they possibly upload it - even if it's just for a short while.
EDIT: Found it- http://rapidshare.com/files/28344419/2007_PLUS_Season_Update__PLUS_.rar
Thanks
yeh the mod 2006 + trackpack and 2007 mod update should be 300+ mb
Hi jojo,Ok Try this - 2006 trackpack part 1 (100mb) - http://rapidshare.com/files/27763153/2006_Trackpack_2006Mod.part1.rar
2006 trackpack part 2 (50mb) - http://rapidshare.com/files/27764593/2006_Trackpack_2006Mod.part2.rar
2006 mod part 1 (100mb) - http://rapidshare.com/files/27758690/2006_Mod_GP4Italia_and_Tony.part1.rar
2006 mod part 2 (50mb) - http://rapidshare.com/files/27764593/2006_Trackpack_2006Mod.part2.rar
2007 update (4mb) - http://rapidshare.com/files/28344419/2007_PLUS_Season_Update__PLUS_.rar
Hope this helps
**** i need to get a faster gfx card i am playing on a A64 x2 @ 2.5ghz , 1 gb of ram and x1950 pro and with the setting on high ( not the best) 1024 x 768 i got a fps of 11 in the test, by friday i will have my new pc built E6600- clocked , 2 gb ram with the x1950 pro but i cant see that being much better .
Should be running better than that, i had it maxed 1280x1024 on a stock 3500+, x1800 XT 512mb and im sure i was getting near the 60fps cap during the test, on the original unmodded version, if thats what your on about.
Hi jojo,
Could you double check your fourth link as it seems its identical to your second one...
Thanks
ps3ud0![]()
CF93 - mind listing what files you had to get?
ps3ud0![]()
