Do we have to find his plane? I found some knocked down trees and something white...
It said report anything suspicious or anything like fuselage. I assume you reported it?
It looks far too small to be mid flight, it would have to be 5-10 feet off the ground for it to appear close to that...
I think that's in-flight, hard to tell with the small PS, I suggest you find out where you have to report it, and report it.
Because he's not designed to withstand a crash and most/all of the ones he's got need activating.Why would his emergency GPS beacon not be transmitting a signal? Surley they're built to withstand air crashes.
