Q6600 B3 to G0, worth it??
31 Aug 2007
As per title guys, would it be worth swapping out my B3 for a G0?
I can get 3ghz out of my B3 at 1.35v, but it generates a lot of heat (low 70's on the hottest core) and I HATE system noise, so can't use a louder HS than I have now (ACF7Pro)
I might be able to pick one up at the right price and basically lose very little if I flog the B3 on that popular auction site ;)
So, would it be worth it, and what sort of reduction in temps could I expect?
Cheers
Well, my G0 is set up like this for daily use:
3.4GHz (378x9)
Vcore on a rock solid 1.352
Load temps 60 62 57 58
TT Big Typhoon with lapped HS.
So you make your own judgments from that.
a decent CPU tower cooler like an Ultra-120 with a low speed fan will be a lot better than that AC7. Bigger fan = more air for less noise.
Yeah, my problem though is that I don't think I have the room in my case for anything much bigger than the AC7.
Thanks for the other replies guys, reckon I am going to go for it!
Got a B3 myself and contemplating the change to G0 just for temps.
TT120 idle @ 3ghz 39-43c
at load they go up to around 60-70c
Thats using 1.25v
How much of a higher clock would I get from a B0 then and is the difference noticeable that much in games mostly and 3ds max when I'm working but that is ram dependant really!
Just seeing if £40-50 is worth B3 -> G0 which will probably be 0.4ghz per core increase?
Thats using 1.25v
3.4ghz should be doable.
TBH I wouldn't bother
Yeah its what I'm thinking, if it is 400-600mhz for £50 and there isn't much real world difference except for benching then it might not be worth it!
Im just fussy and always after the best :D
Thats using 1.25v
Man B3's really need water for decent overclock-
That's 4 Folding clients running within two VMWare VMs. Prime95 temps are another 6-7c higher.
Ask yourself one question...
Will you really notice?
You might when you look at cpu-z :p but in the real world I doubt it.
