I can agree with what your saying james to a point that power ratings are misleading sometimes and different brands perhaps use different ways to determine power output or total dynamic output. Further to this the lower end products id suspect from not just Yamaha but other brands dont quite cut the mustard in raw power terms. This is more to do with the quality of their amplification than the rated power. You will find the Yamaha is not very different in power terms to other leading brands.
My own current Yamaha RX-V4600 uses pretty much the same amplification as this new 1800 model. Its certainly won accolades in the past and also indeed did its successor. So in terms of its amplification really its using what seems as 2-3 generation old amplification.
Comprising of:
7-Channel 910W Powerful Surround Sound (130W x 7 RMS according to Yamaha. To be honest although i dont find it incredibly powerfull i never usually have to take the volume higher than -20 with -30 a comfortable listening level even in 7 channel stereo. The amp itself goes from -80 to + 16 using the digital volume display. So im still well within the units highest ratings in a 16x10 room.
Frank said the following earlier:
Well I guess thats one way to put it - I havent yet put the volume up too far, but hoping to tonight "
Frank also mentioned he had the Pioneer so i suppose hes in a postion of comparing (see below) from experience not just suggested ratings. |We all may prefer the sound of one product to annother but max power ratings are a silly way of determining a products potential. Hell i even dont go by magazine reviews now as these are usually not very accurate or favoured to suit the brands that advertise more with the publishers.
Surely power efficency comes into things as well. Different amps may be different in this regard with some being more econimical in their power usage-power output ratios. Onkyo across all of their products that i looked exceed other brands in power usage, id hardly imagine this to mean that every single Onkyo product that does then exceeds the volume levels or indeed the "quality" of sound produced for each unit compared to other brands. This wont be the case at all.
In fairness Denon seem to be on the higher scale of power consumption too but i havnt compared many of their products...
Comparisons:
YAMAHA RXV1800
7x130w (6Ω, 20Hz - 20kHz and 0.06% THD)
17.4kg
450W
PIONEER VSX-LX60 THX Home Cinema Receiver
7x150W (1kHz, 1%THD and 6Ω)
15.3kg
450w
DENON AVR 2808
7x 110W (8 ohms, 20Hz-20kHz, 0.08% THD)
14kg
6 Amps (USA spec: No of Amps * Voltage = Watts) 6x120 volts = 720 Watts
ONYKO TXSR805
130Wpc Continuous 8ohms, 20-20,000Hz (2 channels driven)
23.3kg
870W
Regards THX labelling and Yamaha, back in the old pre digital days Yamaha didnt need THX because well they exceeded it with their own enchanced surround and DSP modes. Id imagine such a badge is costly to acquire in licensing fees even though they use it on their higher upmarket models as im sure a selling feature for the quality concious and the fact that other competing brands use it to help sell their products too. Chances are many of the required criteria for whatever THX specs need to meet are already being met even if the product itself isnt THX branded.
Just to point out my RX-V4600 which seems to use the same amplification IS THX Select 2 rated (Like the Newest Pioneer VSX-LX60 ) yet the new Yamaha RX-V1800 isnt. Im sure it will make absolutely no difference in audio terms just because they havnt paid the licensce fees this time for this level of product. Denon also seem to have dropped the THX licenscing on their 2808 & 4308 sub £2000 products.
Besides whats the point in having somehing rated like THX ULTRA II if your room doesnt meet the required status for the specification. The Select 2 level meets most living rooms having a listening area approx 10-12 FT from the source. THX ULTRA II on the other hand is for larger living areas and suitable for a room with a distance greater than 12 FT than the source.
Id be interested in knowing exactly what determins THX level of certification because i see it as nothing more than a lavish label, lets face it their are lots of THX branded product that dont live upto their status, so i really question the licensce/quality assurance.
Back to you guys...
Comprising of:
Comparisons:
YAMAHA RXV1800
17.4kg
450W
15.3kg
450w
DENON AVR 2808
14kg
ONYKO TXSR805
23.3kg
870W
Back to you guys...
i think im beginning to sound like a bit of a fanboy. believe me im not, its just that these amps really do deliver and deserve the praise they are getting in the reviews
