Hey, a landing is a landing. You got on the ground and you didn't die. That's a good landing.
Hey, any landing you can walk away from's a good one.
If you can reuse the plane after, it's a great landing!
I was so pleased it was his turn hehe.Didn't think of that. I guess it would have made the air unstable enough to be a problem. The weather didn't seem that bad when I left the terminal.It sounds like you were a bit too cosy to a heavy in front.
I know the A320 is an advanced piece of kit with auto land facilities that control roll, pitch, yaw and trim but it felt too violent to be automated. I can't imagine any pilot letting the machine try and land it under such circumstances.
) well i dunno but I can say that they'll probabaly opt for a visual approach as they like to get as much manual flying as possible... I will if I ever get there
Those are the circumstances when they let the plane fly itself down to 200ft (or further depending on the ILS CAT). A lot of company SOP's insist that the aircraft is not hand flown in certain meteorological conditions.
You say he landed on the left wheel first, this is normal procedure for landing in a cross wind. My friend is a pilot who has just obtained his commercial licence, I remember him once telling me that when there is a significant cross wind they touch down on one wheel first. I have seen this put into practice many times when watching the planes land at my local airport.
Where I work we make part of the landing gear for the Airbus.......I would have paniced !!!!
Commercial pilots generally DON'T do this. Touching down one wheel then the other in a crosswind means that you are using the wing-down method to keep aligned with the runway. The very LAST thing you want to be doing with under-slung engines which only have a handful of feet clearance from the ground at the best of times is to lower one of the wings!!
Nearly all commercial airliners that I know of use the crab method and so crab into the wind and then in the flare (around 10-20ft in a jet) kick off the drift......
tis all good fun tho!
I've just returned from a fantastic week in the Canary Islands and am properly sunburnt and extra fat.
As we head for London Gatwick and make the last turn for final approach the plane started to wobble so I assumed we had a stiff crosswind....
As soon as it looked like we were about 10 feet off the ground, the yo-yo effect kicked in and we started to lose height fast. We literally hit the tarmac with an almighty thump, more than any I can ever remember and with the wobble having sent us leaning to the left, that wheel touched down first.
Whoa
