1 Oct 2007 at 17:49 #1 wesley wesley Soldato Joined 29 Jul 2003 Posts 7,691 Hi guys i need to open and edit a swf file, to change the value of number of uploads then save it. which software u'd recommended? thanks
2 Oct 2007 at 23:09 #3 wesley wesley Soldato OP Joined 29 Jul 2003 Posts 7,691 thanks, just opened the swf file with adobe flash but wouldnt let me change anything thou why? thanks
2 Oct 2007 at 23:40 #4 ic1male ic1male Caporegime Joined 28 Oct 2003 Posts 32,654 Location Chestershire I think swf is the "compiled" version for executing only. You'd need the original .fla file to edit any settings. There are SWF decompilers around but the couple I looked at you have to shell out for and who knows if they work properly or not.
2 Oct 2007 at 23:43 #5 wesley wesley Soldato OP Joined 29 Jul 2003 Posts 7,691 i understand, dont have the fla file thanks anyway
2 Oct 2007 at 23:56 #6 Hxc Hxc Soldato Joined 29 Oct 2004 Posts 12,501 Location London Sothink Flash Decompiler works a treat, btw.
3 Oct 2007 at 00:31 #7 wesley wesley Soldato OP Joined 29 Jul 2003 Posts 7,691 Hxc said: Sothink Flash Decompiler works a treat, btw. Click to expand... thanks i've opened the swf file and exported it to fla file, shall i edit the fla with notepad ++ ? thanks again
3 Oct 2007 at 05:45 #8 dbmzk1 dbmzk1 Soldato Joined 28 Oct 2002 Posts 9,227 Location Stockport / Manchester No, you then open the fla with Flash.
