PSU help!
12 Apr 2007
been looking at the corsair hx520, will it be ok for the following?
OC'd Q6600
4x1 GB ram
1 8800GTX (maybe OC'd)
6x120mmfan (inc cpu)
1 ide dvd-r
1 fdd
2-3 500gb sata HDDs
thanks
In all honesty, your better off with the 620W if your overclocking both the Quad and the 8800GTX and also with having 6x12cm fans especially if their on 12v.
Thanks, hmm was thinking that...I also read a review on the 620 version that said the 5v rail wasnt 100% which could cause problems if running lots of hard drives, I wil be running a maximum of 3...will that be ok do you think?
You could get the Thermaltake Toughpower 750w as its £10 cheaper. Although the Corsair has 30A on the 5v rail and the Thermaltake has 28A on the 5v rail, either will take 10 HDD's easily.
Lol,
heres probably a stupid question,
PCI-e and mobo connectors aside, theres 5 general power sockets on the PSU, now ive managed to rig everything up just using two of these sockets,
Socket1... has a 500GB HDD, a DVD-r, and a floppy attached.
Socket2... has 4 x 120mm case fans, with a spare molex for another case fan, not yet fitted.
Is it ok to put all this stuff over two PSU sockets or should I use more cables to spread the load? I was just kind of asuming the PSU would divert the nessesary power to those two outputs?
Ive got plenty of cables so I can use more PSU outputs if nessesary.
Its probably a stupid question, but I thought I should ask anyway....
thanks.
I tend to spread them over different cables. Like one set for HDDs, one set for fans, etc. It's not a bad idea to distribute the load evenly as you can.
what case is that?
Thanks for that, somthing to think about....Ive currently run out of money so cant afford to finish the build yet anyway...
Case is a Lian-Li PC A10
I might have to flip the PSU back plate around, so the fan is facing inwards, as im not comfortable with the PSU fan only having an inch of breathing space against the case side panel.
