Found the sellers post on itr-dc2.com
The first question is why spend 5k on a rebuild then go for a k20 conversion? Sounds like he was disappointed with the outcome of the mods to me...
And be 250bhp claims without even a dyno to back it up...
Not entirely convinced, it has to be said.
[TW]Fox;10291215 said:Sell it and buy a 318i.
i thought your engine could revving at 9K, why want other 1k? surely it wouldnt make big difference?
The spec:
B18c
LSD BOX
Polished head
2 Skims to head (raise compression)
1 Skim to block (raise compression)
Skunk 2 stage 3 cams
KMS retainers
KMS valves (Valves Re-adjusted to work with high spec cams)
KMS springs
Top line Oil pump
Top line Water pump
OEM Head bolts
OEM headgasket
All other gaskets OEM replaced
Skunk 2 pro series inlet manifold
Spoon pistons 11.6.1
Tuning Worx clutch (capable for 350BHP)
Aftermarket fuel rail
After market fuel regulator
What about other cheaper mods which will improve the fun factor, maybe a new ECU to drop the changeover point. If merlins old Teg is anything to go by that would be my chosen mod
What about the rest of the bits, remapped or aftermarket ECU, decent exhaust manifold, light flywheel etc?
Stage 3 cams will just make you look like a driving n00b every time you try and park in Tescos![]()
A cage is overkill for road use, besides if you go for an exposed cage you should always wear a helmet.
Oh and sod all that.
Just buy an S2000, 240+ hp 9,200rpm out the box and stupidly reliable.
Holds its value well, rear drive too![]()
Keep the money.
