- 3 May 2004
- Kapitalist Republik of Surrey
Decided to detail my car this lunchtime because I was getting fed up with all the scratches and swirl marks in the paint.
Don't have a portapolisher so started with a high quality clean cloth, in this case the oily rag out my toolbox:
Went over the drivers side of the windscreen a few times and boy what a difference it made. I can see out and everything. Amazing the difference it has made on that 50 year old piece of glass:
Decided to go against the advice on forums that I had heard about McGuaiars's polish and settled for a good mouthful of gob on the bonnet. The acid in spit has a slight cutting action and cuts through the grime really well:
I used a rough scrubbing movement back and forth to lift the muck out the paint then turned the cloth over and polished out. The results are quite noticeable, I don't need to tell you which is before and after:
From inside the car the difference is astonishing:
