8800GTS 640 vs 8800GT Benchmarks here
10 Feb 2007
edit: DIRT benches added
edit: Crysis benches added (8800GT only because my GTS is now in the post to it's new owner:)).
I have just spent the past 6 hours benching my new Inno3d 8800GT against my old EVGA 8800GTS 640MB. Results below.
With both cards running at stock settings the 8800GT soundly thrashes the GTS by 20-40% in most benches except 3DMark01. 3DMark01 is heavily CPU limited and I have included it just for reference.
However, the GTS overclocks much better (percentage wise) than the 8800GT. When both are overclocked the gap narrows considerably to a point where there is only 5-20% difference in most benches.
Supreme Commander and Oblivion give much higher frame rates on the GT, but there must be a driver issue with the 169.04's because min frame rates for Oblivion are much worse on the GT.
DIRT is a game that likes top end cards. At Max settings the GT can play this very smoothly with extremely consistant framerates. The GTS cannot keep up and feels choppy by comparisson.
Overall, when both are overclcoked there is NOT a massive difference between the two cards. The biggest advantage of the GT is it's price.
Crysis only really runs smooth at 1680x1050 on Medium settings. Any higher and FPS slow down too much and some things actually begin to look worse. An example of this is distant mountains. On Medium settings they are well defined and crystal clear but on high or very high they are blurry. You also see objects such as rocks and bushes popping up, even at close distance on the high/very high settings. This must be down to lack of physical memory.
At 1280x1024 the GT will play Crysis on High settings smoothly, but very high is too choppy and results in the same image issues as above.
Anti Aliassing is not usable at any res tested. Even at 1280x1024 with medium settings FPS struggles to reach 20 with even 2xAA enabled. Crysis seems very poorly coded. IMHO it looks no better that Half Life 2 EP2, and little better than the original Far Cry. The latter two will comfortably put out >100fps on max settings using a GTS or GT.
Excellent work that man..
Maybe Santa will bring a Q6600 so you can get to the 15K mark on '06
Glad I opted for the 8800GT
Don't get that as my cpu is @ 3.2 hmm interesting same card evga 8800 gts 640mb @648/999 shader clock linked at 1502
are you vista or xp ?
Yea but a bit strange that he scores lower than mine it's the same card same clock and his cpu is clocked faster no idea how that can be.
There's no doubting the gt kicks the gts's butt.
I would off load now
while you can see ok money for your GTX
I suppose it wouldn't hurt, but with them being back-ordered again I'd hate to be left high and dry with a 7300 until it came. :eek: Edit: Sod it just pre-ordered the cheapest OcUK one, I can wait until it's here before listing my 8800GTX for sale. :D
Excellent work there 555BUK, thanks for that - some of the most informative info I've seen yet.
The SupCom benches are slightly alarming, specifically the minimum frame rates. Wondering if the reduced memory is causing a problem here?
Maybe my P5N-E mobo or crappy ram is holding me back a bit. Operating system is Vista 32 Premium so that may also explain it. Either way, both the GT and GTS are great cards and can handle anything (Crysis beta excluded) that is thrown at them.
Fantastic set of benchies mate... very detailed and logically laid out... couldn't have asked for any better! Amazing how much the GT destroys the GTS... 40% in COH... I never expected anything like it for the money. And the OC gain is also very impressive too. Can't wait to get mine! :D
Great post, my main problem is the fact that my GT doesn't clock well enough, so the boost isn't that massive, but i sold my GTS for more than my GT cost and it rocks performance-wise, plus it looks really awesome :)
Dirt ran fine at Ultra settings except shadows, 1440x900/1280x1024 and 16xAA/AF on my PC.
