Your rig should handle it fine on medium at 1280x1024 sorta res.
Extremely optimistic, my rig gets slowdown at those settings and it's a 2.54ghz core 2 duo with 4gb memory and 8800GTS.
i can run the crysis demo all on really high with no aa. there is a little slow down. im running 8800gtx, stock e6600, 4gb ram at 1280x1024
You'll be able to run it on low at a playable fps. Probably. However I seem to be a dying breed of player who can't bare to play at anything less than 40fps. I see so many ppl on here who post screenies with fraps in the corner reading 20 odd and shouting I can run this on high!! No you can't.
20FPS in crysis is just playable. I'd like to bet you wouldnt know the difference in crysis between 25FPS and 40FPS, if fact I would bet my jag!
...i could tell the diff between 25fps and 30fps nevermind 25fps and 40fps! Your eyes can just tell after you've played games for years and years.lol how daft...i could tell the diff between 25fps and 30fps nevermind 25fps and 40fps! Your eyes can just tell after you've played games for years and years.
EDIT - damn i was beaten to it!!!
There's a difference between noticing it being lower FPS and it becoming an issue.
lol
Once again, it's just like MP3 quality. Some people can tell the difference between 192KBPS and 320KBPS and some people can't.
Personally, I can see the difference between 25 and 40fps on a lot of games.. but not on Crysis.
wish i could see it running like that with all the eye candy on tbh
