Glasses, do you wear them?
I can honeslty say i need glasses. its got to the point where i dont even try to read subtitles on tv as there just a blur. and i cant see like motorway signs till i get about 20 foot from them (sat nav ***). i've been meaning to go for an eye test for the past 8 months but i've just constantly put it off.
That can be dangerous for other drivers mate you should get it checked out. If you dont like glasses you can always try contacts, its only bad for the first week then it becomes a toddle.
I wear glasses, for the last 5 years i've been wearing them all the time, my eyesight has always been bad, but i never really noticed it until i was about 10 for some reason :P. Worn glasses ever since.
I have a slight error of correction.. Not sure if the opticians was talking about me or my eyes.
I have to wear them whilst doing computfdf fer work but I lihtink imyyy eyeyeee ldoi sight isss ooii kok sjnhfcjoiofv :)
Your slight error of correction could be too much feeding the ducks, Admiral.
Repeat the hand movement required and you may see what I mean. ;)
Its not that bad. i can see everything just can't make out writing till im fairly close. i'd be ****** if i had to do that eye thing on the driving test. but i really am gunna get an eye test soon
No swearing, JG
stumpy187, your eyesight might not be that bad but your understanding of the FAQ appears to be, you need to edit out the swearing sharpish or you'll probably be suspended.
I do know the feeling though about distance, I can make out objects pretty well in the distance but I couldn't read a bus number from probably 50m away and be absolutely certain. :)
Eerrr stumpy187, you're supposed to see the signs from about 50m away and not from about 5.
I do wear glasses. Not entirely sure if it due to using computers. Didn't really get glasses before I had been using a PC for a while.
You really need to ask? :p
Phew a like minded person. :D
I wear glasses/contacts when I can be arsed.
Do any fellow glasses wearers notice how they leave a slight indentation in your head behind your ears where they constantly sit?
