it's the same but less power.. ive said that all the long.So whats the verdict then if you have a 2900XT, worth the change to a 3870?
Now I havent even done the 7.10 driver test yet but one thing is pretty much certain which is why I am cutting the testing short for the card. This IS the HD2900 and clock for clock you can match them up and they will perform the same at the same speeds its that simple. So after the overclocking I will be easily able to conclude this review
You sure the AA aint improved with the 3870?
i think it's the same.You sure the AA aint improved with the 3870?
what is the 3870 clocked at? 775 or 777
Well Will, the OP has done a bench with CSS and AA is applied, try doing the bench with the same settings and see what you get.
Very wierd that the 7.10 drivers aren't working.
Don't forget that the cooler doesn't look anywhere near as good at cooling as the old xt variant. Obviously your getting a much quieter cooler, but have you tried benching the card with the fan on full blast? I would also be interested in learning about vcore increase and see what the card can do with a proper cooler.
Is it still quiet even overclocked to 860?
Matthew
Yes the card was silent with the OC and that was impressive but makes me think it is just set at a specific speed and told to sit there! I dunno but we definately need the 7.11's and these will no doubt come on release day of the cards or the week after!2DVi's and a TV-Out just to let you know quickly![]()
