There are 3 Gainwards in stock people!!! Check out the site http://www.overclockers.co.uk/productlist.php?groupid=701&catid=56&subid=1008
I think thats the first time I have seen stock on the OC site, I ordered my eVGA superclock on the 29th about 40 mins after they went up for pre-order on the OCUK site and unexpectedly received it on the 2nd of november, so hang on in there guys who are waiting, its worth it.
that isnt fair
i ordered on the 30th and am still waiting![]()
Well I'm just off the phone with OCUK, and the BFG 8800's are in today![]()
Weee!Well I got an email this lunchtime from ocuk saying bfg have arrived but not enough to fulfill all the pre-orders
So depending on when you ordered your bfg, you might get it tomorrow or you might still be waiting.
I just called them and asked if the BFGs were in... Apparently they are due in today or later but as of now they have none in.
I just called them and asked if the BFGs were in and if I'd get my order shipped.
No. Apparently they are due in today or later but as of now they have none in.
So I changed my order and got the last Gainward GT
Should be leaving OCUK todayWeee!
Good man, afterall its the same card as all the others, just has a Gainward sticker on it instead.![]()
that isnt fair
also, if adding a third party cooler will it void the step-up with evga and what temps do you get?
just put the stock cooler back on if you have to rma it or step up, as for temps, I am using the stock cooler for now, after setting up rivatuner fan profiles I idle at about 51-52@40% fan speed and 71 is the highest I have seen it under load, I have an 80% fan speed kick in when I hit 70 degrees.
hmm hardly the need for an S1 cooler then![]()
