- 6 Dec 2002
- North East
Yep needs Dual link which the macbook dont support.
Called apple today and was easier than i thought it was going to be ...they are arranging a courier to come collect it this week.
Just unsure on what to do now....order a macbook pro replacment or hang on for the rumourd PRO in a macbook chassis.
One thing i did notice in the short time ive had the macbook was how slow it was at opening the various included apps....is this nomal with a mac?
It only had the 1gig of ram would 2 cure this?
Thanks
I don't think it would make much difference unless the RAM had already been used up and it was having to load things in and out memory. 2Gb will allow you to open more programs and not encounter this problem. You'll also find that having the MacBook plugged in will increase the performance otherwise you have to force the MacBook into the higher performance while on battery.
Not sure on how long before the new MacBook Pro's but now is the perfect time for a MacBook
BeatMaster
Although the MacBook Pro does have a backlit keyboard
