HI
Im having some problem since a few days ago.. I was playing crysis normally with minors bugs but then when I was entering to the mission assault, my PC start to behave weird. all levels before this work fine... in this When I load the game.. some sort of artifacts start all over the place and then crash to desktop with the nvlddmkm driver thing... and sometimes after the artifact im able to enter the mission (with no artifact in the mision) but later on the same mission the game crash.... any solution... I already try this:
Change drivers: 169.04, 169.09, 169.12 (properly uninstalled and using driver swap)
Uninstall X-fi xxx.004 drivers.....
re-install the game
re-install windows
Its not an overheat problem.. my temp is fine. But i had some problem with COD4 too.. not artifacts but the game crash just a few minutes after I enter some missions... But I kinda solve this... uninstall my X-fi drivers and finish the game without a problem...
Its very intresting because the sound drivers didn't fix crysis just cod.... then when I try to install my xfi driver (xxx.004) the PC stop responding with some "artifact" look alike and freeze. I had to reboot and try t install the drivers again and worked....
I also was watching a serie using the dual monitor, my pc monitor and my TV.. when I start to notice the "artifact", then Stop using the dual monitor and use my PC monitor and problem solve without a reboot......
I called artifacts because I dont know what else to call it. artifacts are small dots, this are big ones in top of my screen usually.
It this nvidia drivers problems? X-fi drivers problem? or both? My PC was working fine few days ago... suddenly after new nvidia and x-fi drivers my pc is a disaster....
Anybody with the same experience???
re-install the game
re-install windows
