Hi
I remember seeing a link o a website with a hugh list of very good wallpapers. Anyone know where it was again?
May have been Interfacelift.
New monitor demands new desktop image...
And my logon screen is this...
Loving the wide screen goodness.
InvG
InvG
How did you change the wallpaper on the old logon screen? Thanks!![]()
Could I have the link to that wallpaper please?
Sure, here. It's such a nice image, but looked slightly wrong as my desktop background, so set it to the log on instead.
InvG
Sart > Run > regedit
HKEY_USERS > .Default > Control Panel > Desktop
(only highlight the desktop folder thing, don't open it)
Wallpaper > <directory of your image - must be a bitmap (*.bmp)>
Mine is 'C:\Documents and Settings\LogonPapers\sky.bmp'
Hope that helps.
InvG
You could try doing it with TweakUI (Download here) which can synchronise your logon background with your desktop background.DOnt think its working....
Have i done it right?
*snip*
I tried it for both bmp and jpeg and when i push the windows button on my keyboard and L, no picture wants to show up.
Convert the image to a .bmp, edit the registry again and link to the .bmp then it should work![]()
Also make sure you restart the PC. It has to reload the registry to load the new image in.
InvG
All sorted now, i had to go into the control panel then into 'user accounts' and click on, change the way users log on and off.
Hit the nail on the head.I don't especially like the car, it's too bright,
