Baddass could you find time and kindly contribute regarding this debate. Me and IceTea it seems are still divided regarding the OcUK 24" and Pebble 2232W Sammy. Please refer to my previous post regarding this too. Let's not let this become a I own THIS lcd therefore THIS is better and vice-versa. That's why we need an unbiased informed decision.
Right here is my opinion of the heated Samsung SM2232BW vs OcUK L2442W (or similar) debate which seems to be going on. This is totally impartial, I do not own either, but I've tested enough screens to hopefully be able to give an overview of the pros and cons of each:
Response Time - the Samsung features a 2ms G2G Samsung TN Film panel, with overdrive being used to offer some very top end responsiveness both on paper and in practice. The SM226BW is highly regarded, and the SM2232BW is using the same Samsung panel as that did. A very good panel in terms of responsiveness, and about as fast as you will find in today's market. The OcUK L2442W features a 6ms G2G rated VA panel, again using RTC. My suspicions are that this is a P-MVA panel from AU Optronics panel (as used in the BenQ FP241W). Even if it is a Samsung S-PVA panel (as used in the Dell 2407WFP) then it is still very comparable in terms of responsiveness anyway to the AUO P-MVA panel. Both are 6ms G2G rated, but more importanlty, in practice, the observed responsiveness is very similar. You can compare this with the images as reviewed at BeHardware / Hardware.fr / DigitalVersus
here.
Anyway, regardless of whether it's a Samsung S-PVA or AUO P-MVA, both are very comparable in real terms to one another. It's debatable as to whether you'd notice much real difference in practice between these and the 2ms TN Film panel in the Samsung SM2232BW. However, the Samsung is a little faster in tests. You can see Xbitlab's response time testing of the 226BW
here and see that it is pretty top notch. While Xbitlabs haven't reviewed the FP241W (most likely panel match), Tom's Hardware have, and you can see their response time measurements
here. Anyway, I digress. Both are good, but the edge would go to the Samsung SM2232BW here. Whether it is an issue is another thing, but that depends on the user....
Neither screen offers hardware level aspect ratio control, or 1:1 pixel mapping, but it should be possible on both screens via software (e.g. Nvidia control panel - maybe some users can confirm here?)
Contrast ratio - the contrast ratio of 3000:1 listed for the Samsung SM2232BW is dynamic, the real static contrast ratio is 1000:1, which is the same on paper as the L2442W. In practice, for a TN Film panel, the SM2232BW performs pretty admirably in this regard, with a recorded contrast ratio of 946:1 in
Behardware's tests (S panel in the SM226BW used for reference). If you compare this with the recorded contrast ratio's in
their tests of the likely panel matches (BenQ FP241W and Dell 2407WFP) it is actually a little better:
So despite being TN Film, the SM2232BW could well offer the slight edge here in contrast ratio. With it's dynamic contrast ratio, it might offer some further improvements in videos as well (since that's really the only proper use for the tech imo). Having said all that, the contrast ratio on the L2442W should still be very good, and it's pretty hard really to spot a difference in practice when the figures are this high and this close, once you have the screens set to a sensible luminance level.
Colour Accuracy and Depth - Firstly, despite the figures being both listed as 16.7 million colours, the Samsung SM2232BW only offers a true 6-bit colour depth, with
FRC technology being used to boost the colour palette from 262k colours, to 16.7 million or thereabouts. The *VA panel of the L2442W on the other hand features a true 8-bit colour depth. In practice, if you consider modern FRC algorithms, you probably would never spot any real difference anyway, it's just something to be wary of, and something some people like to mention
Colour accuracy is a tough one to compare since this really does vary from one screen to another, and is not entirely dependent on the panel used, but more on how the screen is set up out of the factory. You can't really rely on the IPS > VA > TN Film rule here which some people like to use for colour accuracy. Both are perfectly capable of some good colour accuracy if you can calibrate them properly, and nowadays even TN Film can offer good performance here. Hard to say which would offer better colour accuracy out of the box though. Whether people set them up to their tastes manually, or use a calibrator, both should be quite similar in terms of accuracy
Where the colour capabilities will vary is related to......
Viewing angles - this is where TN Film suffers. The VA panel of the L2442W is superior here. This can influence nearly all uses, including colour work, gaming, movies and just general use. For many, TN Film is still perfectly adequate, but imo, 22" is the limit of where you can use it comfortably without viewing angle variations really becoming a noticeable distraction when using the screen.
Resolution and Screen size - Obviously the edge goes to the L2442W here as has already been said. It's 2" bigger, but more importantly, the resolution is higher. Imo, the 1920 x 1200 res is a really nice (and noticeably quite good) upgrade, and really allows better side by side working and more desktop real estate. The pixel pitch is slightly tigther, and again, imo, this is better, a little sharper and improves text clarity a bit. Again, this is down to personal preference, but i personally find the text size and pixel pitch a little bit too large on 19" and 22" models as compared with 17" and 20" which share the same res, but on a smaller screen.
The 1200 pixel vertical resolution allows for full 1080 HD content to be displayed too, but without the need to be scaled by the monitor because the res of a 1680 x 1050 screen is not quiet enough. For gaming, the extra resolution of the 24" model is there for if / when you have aq powerful enough GFX card. Imo, it's better to have too high a res than not enough to allow for future expansion, and so it is probably better to have a 1920 x 1200 res from the outset. you should be able to use aspect ratio control at a software level anyway, and so if you wanted to, you could run at 1680 x 1050 and use 1:1 pixel mapping to put borders around the screen. It would be like having a 22" screen within a 24" model
Obviously, you can let the screen interpolate the image up anyway to fill the screen, and on modern displays, the quality of this tends to be very good anyway. Seems the user comments here suggest it is of good standard.
james.miller said:
another point, what good is 1:1 mapping on a 1680x1050 panel? it wont display 1080p. 72-p it would, fair eough, but 720p on a 22" panel? hardly worth the bother for 1:1 mapping is it?
Don't forget the 1:1 pixel mapping is also used to control aspect ratio if you're viewing a 4:3 or 5:4 source....so it's just as important at 22" as well really, it's just useful on WS format monitors.
Features and Design - Neither offer much in the way of ergonomic adjustments, only a tilt function. The design of the SM2232BW is nicer i think, and i'm sure most ppl feel the same there. The speakers on the L2442W may be good for some people, may be off-putting to others, again down to personal taste. The apparent lack of HDCP on the L2442W throws in problems for any encrypted content, whereas the SM2232BW features it over DVI interface. I'd say the Samsung wins here, but then we already know it is a more premium design than the DGM model. Note that build quality and materials are likely to be better on the Samsung as well.
So there's my opinion of the two models. Both have their pros and cons, and i guess both would suit different user needs. If it were ME, I think I would get the L2442W as I prefer the larger screen size and resolution, and find the viewing angles of TN Film to be an unwanted distraction. That's only for me though, and considering my personal everyday uses.
Barba Gann said:
For myself: I need an LCD to play games mainly and watch dvds and browse - I love the 24" size and will be looking at the monitor slightly below its centre point since I lean back on my swivel chair. Please help me decide which one is my best bet since I don't have the luxury of seeing them both near each other and comparing.
For you, I would say the VA panel of the L2442W would be more suited. Viewing angles would be a problem if you're viewing the screen from any angle really below a central view on a TN Film panel...the contrast shift is obvious on TN Film in that instance. For movies, the extra size, and wider viewing angles of the L2442W would be better imo.
