The money shot:
And you can see 18 more one at a time with descriptions or all at once, without.
Hope that's useful...
Yes, very helpful....and a good bit of work!
The money shot:
)Holes on the back of the panel.
Ali-Longden, have you already mounted yours on a wall, if so can you post a pic?
have you tried turning the stand as when I tried it seemed to go in better in only one way?
The base can go in only one way, if I put it in the other way it wont let me (hole sizes are different).
A bit frustrating.. how much pressure do I need to apply?
Anybody?
Theres a little plastic thing you're supposed to put in first, between stand and monitor that I saw when reading the instructions (after I'd already locked it in of course).
Seems OK without it though.
Can anyone shed any light on the base issue? My base doesnt want to click into the neck.
and then put the retaining toggle thing in.Does it go click?Hmm no matter what I do, I cant get the base to click into the neck of the monitor. Pushing down pretty firmly, dont want to exert too much pressure mind.
Anyone have any ideas?
Gibbo said something (search?) to the effect that this bath had all the same panels. He also said (IIRC - search) that if the next batch had different panels that OCuk would clearly differentiate the products.Are all the panels the same in these Screen? (i.e. no Samsung/AUO lottery mumbojumbo) ?
No, the 6 screws are just used for the base. They're much too small for the VESA mount.Holes on the back of the panel.
From the pictures that lbt has posted, we first remove the base, then attach the monitor to a mount, using the 6 holes shown in lbt's photograph.
Is your monitor's base loose or something? You might not necessarily need to hear a click. As long as the monitor is reasonably stable, the click is irrelevant.
